i have done some searching around on the net and sm and can't really find what im after.
i need to flush my tranny fluid. But i don't know what to use. stock is 80W-90 GL4 or 5 gear oil. however i think i want something that will take a bit more abuse and be good for high mileage trannys.
what do you guys use and what do you think of it. is the stock stuff good enough or is there better. brand names would be great as well.
on a side note i need new pads. what are some good brake pads. i want a pad that won't fade as much at high speeds. i may invest in some front slotted or slotted/drilled rotors for the front. just oem replacement though
thanks guys
thanks guys
