1 - 3 of 3 Posts
i've gotten rid of the pcv system, but there is still a lot of oil in my ic pipes. it seems to only be after the intercooler, im guessing it is full of oil? can i just remove it and flush it with water? could all the oil casue any problems with my bov?
Question to suit.
if you clean anything with oil on it, don't use water. Use some gasoline :)
The oil could be coming from your turbo, but I'm not sure. Just clean it, and check it again during your next oil change to see if there is any more oil in there. It could be residue from before you removed the PVC.
Moderator, l337 M0d3r4t0r
i don't think it's full of oil maybe a coating but as he said just run some gas shake it around and pour it out...
1 - 3 of 3 Posts
