I pulled my intake plenum off and found oil pooling up in the intake manifold runners. Here's the situation and my question(s):
- The engine was recently rebuilt, but the car smokes (blue smoke, mostly after idling and when you begin to accelerate. Also smokes a bit between shifting gears).
- Wet/dry compression test was 'supposedly' in specs (performed by a third party Toyota dealership)
- The dealership could not confirm if the smoking was from a bad valve seal (no visible leakage when the cylinders were checked with a scope). Though the dealership believed this was the most likely cause.
- One mechanic thought it was probably a bad PCV
- Two other mechanics were certain it was the turbo, especially after seeing the amount of oil in the IC piping. This seemed likely to me, since it was a rebuilt turbo with 80K+ miles on it
- Installed a NEW turbo. Car still smokes.
Any ideas? I'm going to install a catch can soon... think it will help?
There are some pretty smart MKIII owners on here and I trust your diagnoses more than some of the mechanics I've run into.
Thanks for sharing your wisdom!
Destroyer of Turbos
could be blow by and or bad valve seals. what was the compression on the test?
I would have another mechanic check the valve seals. Oil in the intake pipe is normal because of the pcv system routing back into the pipe. Getting a catch can will keep the oil out of the intake pipe. Is your pcv system still in the stock locations?
Durrr said:
try using a thicker oil w/ some detergency in it. pick up some 15w-40 rotella and put it and let the car chew on it for a while, could help things out.
How will this help?
Yes, the PCV is still in the stock locations. There is about a teaspoon of oil in each runner, after it pooled together. Is that about average?
