I would say that is normal in most situations, but I would not say it is correct. Bottom line is most turbo cars collect oil in intake and plumbing, ect. but honestly you shouln't. Clean everything up, change your PCV and run a GOOD catch can there and at the breather port. Check for oil before and after turbo compressor if you have more oil in the outlet than the intake, your turbo is leaking. Other than those 3 places, oil cannot get into the intake. BTW, you DON'T want oil going into your motor, it just makes a mess of things.
Also instead of running a catch can, you can run an exhaust drawn PCV system, those are awesome.
