Status
Not open for further replies.
1 - 20 of 46 Posts
wtf...
can anybody tell me wats wrong with it??
any idea ?? he told me that no leaks after he finished the oil change.. but when i get back home.. leave my car in my garage, after 5 hours later.. it leaks like 20 drops...
thats crazy..
Depends on the year and the model.
For example my 97 turbo, when replacing the filter oil leaks directly down onto suspension and stuff. And can drip off later.
I'd check to see if the filter or plug are leaking. Those are going to be the only things they would touch.
Professional Walmart Oil Change Technician. Anyone see a problem with that title?
Check the oil filter. It may not be on there tight enough. This happened to me once after I had gone to my usual oil change facility. I had taken the car the next day to have the brakes done and the Toyota mechanic noticed that my oil filter wasn't screwed on tight enough. Let us know if this helps. :)
i hope that is the problem let it drip off ..
hope tomolo morning when i wake up, my garage will be clean as usual if not... sigh..
i wont bring to walmart express lude do the oil change no more....
pirates like cookies
wow, you take your supra to walmart.. and let minimum wage people drive it and touch it... yuk man
heartbreakkid said:
wtf...
thats crazy..
Ohh I didn’t know they did oil changes.... On another not, WTF are you taking your car there for an oil change!? :rolleyes:
nope :rolleyes: :rolleyes: :eek:
his first mistake ..walmart
Discussion Starter · #13 ·
i saw the dash light blinking (oil need to be added) today when i drove my car to work so i just bring it to walmart since that is place near by... well, have my first experience but i dnt think i will bring there no more/.
i will let u know if something happen.
thanks
Just Cruisin' Thru
:agreed: My car was delivered with the oil filter loose and was leaking only after dissolving some of the undercoating making a real mess. Changed oil, put new filter on nice and tight - perfect.
Also, check around the plug to see if there is fresh oil there. You know, wipe it and then check it later to see if it is still clean, esp. after you drive it.
Taking car to Walmart: :nono:
wallmart.... umm... I know everyone has given their opinion.
i just want to explain what I almost did when I read the title of this thread:
I almost drop kicked the computer lcd!
I feel like punching someone.
:box:
Number three Hardtopper
Just to let you know the best oil filter is the Japan filter for our cars from toyota. They allow the most oil flow in and out of the filter and they have been proven to be better.
Don't take my word for it check the mkiv thread and see for yourself.
Also is your supra an Na? I would feel better knowing you took a non turbo to walmart than a turbo.
I don't know the setup at my walmart is better than most shops. And you can pick the brand of oil you want.
Whats the other choice for the guy, Jiffy Lube. Yeah theres a good choice. I want my oil changed by a 15 year old high school student.
My opinion of Toyota mechanics is even lower unfortunately.
Toyota filter
heartbreakkid said:
can i ask about something?
is the oil filter u guys use from toyota dealer or any oil filter??
let me know again thanks
What kind of oil did you use?
1 - 20 of 46 Posts
Status
