1 - 8 of 8 Posts
Search function isn't working right..so I'm posting this.
Anyone ever had an oil leak from what appears to be the oil filter housing / cooler itself? I ordered all the gaskets/orings for it.
Anyone ever had to replace them? Theres quite a few orings/gaskets so I'll probably just replace them all.
You sure its not starting at the valve cover and leaking down?
Boost Junkie
Yes,
Check the cam cover gasket on the intake side before going through all of that trouble. Mine was leaking due to the gasket being pinched. The oil cooler is only held on by one large bolt and has 1 oring.
Steve K.
Mine sweats a little oil out where the oil filter housing / cooler is assembled to the block. It's not easy to see in this area...
I'll have to take it out and re-seal it ...
Kwan Jul Sul Freak
I have the same leak. I changed the two orings in the oil cooler and it still leaks. I gave up. The oil cooler is easy to remove and re-seal however. The pain is getting to it. Lot's to remove.
Remove the battery, powersteering reservoir, Oil filter and oil cooler, replace the "O" ring between the block and the cooler retighten the hell out of the bolt to the cooler and you leak should go away.
1 - 8 of 8 Posts
