#1
I'm removing the T78 oil line going to the turbo today, and need to know what fitting I need to replace it?
I've already got the return taken care of, and was able to reuse those pieces...
Please help me out as I'm trying to get this done as we speak..
#2
P.S.- I've got a -4 AN line I got from turbonetics coming off the turbo going to the block...
Just need to know what size adapter I need to buy for it to screw into the block...
#3
Is it 12mm x 1.25 thread pitch?
I know somebody has this information!
#4
I'm sure they make a 12x1.25 to -4 straight fitting. I used a Banjo to -3 for mine. I know they make banjo to -4. The company is called XRP.
Lawrence
#5
You might want to call up a shop that makes high pressure hoses and ask them if they have a 12x1.25 to a JIC#4. (JIC#4 is the same as -4)
Hope this helps.
Lawrence
#7
Riggs said:
So, the fitting is 12 x 1.25? Correct?
Yes.
#8
I got that figured out, and got the part....
What about the return line? What fitting is required for that?
