1 - 3 of 3 Posts
hi gugy.
i bought the 94 Supra TT i going to have full service enging oil coolaint ,difi oil ,gear box oil but befor i change the engine oil shell i remove the oil pan and clean the it Bcoz the previus owner change the oil after one year.its better the clean the oil pan befor i put the fress oil? or???? any other way
From the land down under
Just jack up the car on a steep enough angle so that it drains all the oil out properly.
If you just jack up the car in the middle of the front end, about 500mls of oil wont drain from the pan.
OG
In order to pull the oil pan you'd need to pull the engine; might not be worth the hassle. If you're concerned about getting all of the oil, I would change the oil a couple of times in afairly short timeframe. I'd also use Seafoam in the oil before those few oil changes.
1 - 3 of 3 Posts
