eh, it worked for meVitek said:When I did mine, I was thinking that I could clear it by just jacking up the engine. I got the engine as high as I safely could, but it still wouldn't clear. In order to take the lower oil pan off (black one) you have to lower both of the cross members and raise the engine as high as you can. That’s the only way, unless you want to pull the engine. It's definitely a big PITA to do. Good luck.
