no prob, i will know shortly if the dealys are going to be too severe, if not i think i may have found another engine, although it is missing the ecu and has a cut harness. oh well. let me know when the transaction compltes itself
W'sup everyone,
I've been on supraforums since my first car (2010ish), but this will be my first time posting. Hopefully i don't get trolled on.😑
Ive done a Aristo 2jzgte vvt-I swap on my ma70 chassis Listed below are the details. Hopefully yall can helpme out.
-Door jam badge 11/88
-title 1989...
Non-VVTi 1JZ-GTE here with 87,000 km's
Car starts up and fires perfectly fine, and no idling issues at all. Runs great except when I'm brake to a stop in neutral, to which I have to start it right back up again.
It doesn't happen all the time, but it is very annoying. Is this usually a...
1jz Vvti
This is on the Turbo side of the block, I have no idea what its for or what it does or what I should do with it?
Please let me know thank you!
Noticed that under load my 1JZ is bogging right at the transition point of positive boost. It almost backfires slightly depending on load, but once under boost runs like a scaled ape...
The on/off transition seems more single-turbo like than the normal smooth twin action. I had originaly...
Well, I have a Lexus gs300 with over 200k miles. I was going to turbo the engine, and when I took off the throttle body I seen oil. And also in the spark plugs, then I continued to remove things. Till I took off the intake manifold, so they had oil in there as well ? Crack heads ?
