First off, what is you oil pressure, and where is it measured? and does anyone know if there should be one or two springs in the pressure relief valve?
Boost4fun
The oil pressure is around 7bars at higher RPMs IIRC and the OE sensor is on the left side of the block a little up and in front of the oilfilter assembly. But you can also put an aftermarket sensor into the oilfilter assy by using a Lexus hollow screw there.
The article is here:
http://www.mkiv.com/techarticles/oil_sensor_mod/index.html
Hope that helps.
Gerd
P.S. Double post??
Thanks for the input, but that is not exactly what i'm getting at,
I have a oil pressure gauge with the sensor in the oil filter sandwich plate, and i get high oil pressure 115 PSI, i was just trying to find out what sort of pressure other people get and where their take off point was,
I also have two springs in the pressure relief valve and i have looked at the manual and it only shows one.
Boost4fun
Unfortunately I can´t tell anything about the springs of the bypass but your oil pressure seems to be within the normal range. People reported between 7 and almost 9 bar.. The sandwichplate is a good spot to measure the pressure.
yep seems to be ok, supras seem to be blessed with fairly high oil pressure if i can say but it's a safe pressure and high ish is better than low.
Be warned over filling causes excess pressure and will cause crank seals to fail :nono: yep i've learnt my lesson the hard way :agreed: lol, two spring and a little ball i believe, shake it and you should here it rattle if not clean it (petrol).
Discussion Starter #6
The PRV is actually a cylinder and if it rattled i would be extremely worried, yeah overfilling will kill oil seals on most engines.
