1 - 8 of 8 Posts
1989 7mgte swapped mk3
I was changing the radiator today in my 89 n/a and I started it up when I finished to take it on a spin and i'm gettin no response out of the oil pressure gauge. However, when I was pulling the lower radiator hose I did pull a wire out of place...it was yellow with a black stripe. I think this is the reason. Can anyone tell/show me where this wire plugs in? Thanks
BMM
yup thats it. just look for the other end of it. it cant be too far, the wire is only so long.
true...I just haven't had time. I been busy with the radiator. Just got lazy and came to SF
where is it located? I'm sure I can find it fairly easily...I just haven't gone to look yet.
it should have a big black "condom" on it - it attaches to the oil pressure sending unit directly below the ps resivoir - you're probably going to have to move alot of things around to get at it. Also, it slides on to the connection sideways, it does not plug straight on (i found this quite confusing when I was trying to plug mine back in)
1 - 8 of 8 Posts
