Mr2 Owner :-D.
Now i own an mr2 and we all got oil pressure gauges but the community is much smaller than the supra community so i am bringing this question to you.
Has anyone ever seen or had a mechanical oil pressure gauge line ruptur and spray burning oil all over the cabin or over the driverr?
El Pollo Diablo
It could happen, so I'm sure it has.
Closest I've come was a line to a mechanical guage swinging into the turbo heat shield, insta melting, causing a nice little underhood fire.
thankfully, the engine side of that line cauterised instantly.
I have always been aprehensive of that little plastic line that comes with aftermarket gauges. I've actualy had it burn through in the cabin of my 4x4 toyota truck due to a wiring short. 40 to 80 PSI but very low volume. Nothing to worry about. I have one installed on my 89 Supra with no problems. Do keep it away from the turbo heat. I keep a spare sensor with my emergency parts so if it blows out someday I have something to plug it up with.
Oldie but a Goodie
I'm all about mechanical oil pressure guages, but using plastic hose for it is just asking for problems. Get some copper/bronze tubing and run it with that. As long as you don't screw up your fittings you'll never have a problem.
