Hey I looked on my car and I searched on here but I haven't been able to figure out where the sending unit is on my block... Please help me:hail:
on the 1jz engine, it sits on the block behind the A/C unit. kinda small and tucked away and you will need to remove the throttle body, and the power steering pump to even attampt getting to it unless the engine is out.
It's the one in front of the oil filter...right?
No Longer that n/a 1j guy
I didnt know it was located there..... Whne I had my twins set up, I had one of the banjo feed bolts drilled and tapped for the thread of a 7M OPS. Worked great....
well kinda, its tucked away in the corner and is smaller in size compared to a 7m OPS. you can see it if you look behind the AC compressor brackets in right behind the timing area.
I just attached it to one ofthe flanges on my oil filter relo kit. Still doesn' work tho. I need to install my spare sender :-(
