1 - 8 of 8 Posts
DONT HASSLE THE HOFF
Anyone done this mod for an Oil Pressure gauge? If so, how the hell did you get to the Union bolt? From the top or bottom? I didn't get down to it yet just crawled under the car for a look and it looks like a PITA from there and almost worse from the top.... Anyone, any suggestions?
Thanks-
AnArKey said:
If you have a single turbo, I figure the rear oil feed on the passenger side of the block would be much better.
Unfortunatley I have not made it to a Single Turbo yet, rebuilt took more than anticipated out of the wallet. MKIV has a write up(kinda) on this mod but not specific directions, just looks hard to get to that damn bolt by the Oil Filter.
Its pretty simple, Remove the power steering pump. I think its 3 bolts. Remove that to the side and you should be able to access it from the top. Your going to need a long extension on your wrench to move the union bolt. Other then that its pretty simple. I had a tough time deciding top or bottom, but top worked for me.
thanks
leonard
Thanks for the tip Leonard!!
And I did mail Mani about this but never got a response...so I came here and asked.....
Mani showed me how to do it. So i'm just the "middle man"
Just passing the information along..
thanks
leonard
1 - 8 of 8 Posts
