What is normal oil pressure for a 87 7mgte
I have read 4 psi is the lowest
I'm using my stock gauge...yes I know the stock oil gauge don't always tell the truth
My car sits at 40 psi cold idling at 1000rpm
Warmed up and cruising at 65 its right around 35 psi
Warmed up at idle at 700-800rpm its a hair under 20
Is these readings pretty normal? Idk what weight the oil is
Also what weight oil should I use?
This is my dd and I drive it at highway speeds 80 miles round trip
In Ohio during the summer its normally around 90 degrees outside
Also I was thinkin about running synthetic oil but had some concerns with sludge getting cleaned out and making some leaks appear
Motor has 154xxx miles and from what I can tell it has never been rebuilt
Has anybody switched over to synthetic at these high miles?
