1 - 3 of 3 Posts
noticed today when i had the car in park that there was a oil dripping down. looked like it was dripping from the turbo so i popped the hood and looked around the turbo and there was a line next to the heat shield which went into the turbo which had oil all around it is there anyeay to fix this?
I hope what your reffering too is not the Oil Dip stick. This is next to the head shield aswell by the turbo. Anyways, there is a metal oil line coming from the bottom of the turbo. It splits into two lines, one for intake of oil and one for oil drain back to the block. That's the only place it can leak oil, which is BELOW the turbo. The only other lines going to the turbo are the coolant lines.
If its oil coming out of your dipstick, you got other problems. Possibly too much crank pressure or a very very clogged PCV system.
hopfully its not leaking from the oil lines going to the turbo.
goodluck
1 - 3 of 3 Posts
