I bought a manual boost controller can u guys tell me how u hooked it up maybe a picture cause i cant fiqure out why i need to run a t fitting or do i. Cause it seemed to either hit fuel cut or go to 7 or 8 psi and it was really unpredictable where the boost was going to be cause it was different in every gear. I couldnt get it to go to 12psi. Makes me never want to buy a MBC again.
you shouldnt have to run a T fitting. I used a regular old pressure regulator as an MBC and just put it between the turbo and the wastegate. If you hook it up like that and unless you have other leaks or problems then it should be ok. do you have any other mods? did you shim your wastegate? etc
