are you talking about the MAPECU? If not, be more specific. That piece is made by Performance Motor Research in Australia; Powerhouse just sells it.
If you mean the MAPECU, I had it when I had my small single and it's a very good fuel controller which also eliminates the MAF, ie. converts you to MAP based fuel control. Since it piggybacks off the stock ECU (I had a gforce moded stock ecu) the driveability is easy to keep virtually flawless.
As far as 450whp on stock twins, you don't need larger injectors or another pump to do that...as long as your stock fuel system is in good shape. But IMO you'll have to run boost high enough that you'll need racegas to be safe, otherwise the stock ecu will be pulling your timing when it senses knock....just driving and reseting the ecu, driving resetting etc is bad practice imo and will eventually take a toll on your motor.
