Rebuild with forged pistons. Don't listen to Ryeno he is a fucking tool bag.
1. You can easily remove the distributor. Its not like it is welded to the block. There are a billion easy ways as well.
2. Piston quench only becomes a problem with thick headgaskets.
3. You don't need oil squirters with forged pistons. Majority of them will be much larger as well so you CAN'T run them.
In the long run, its much easier and cheaper to run the GE block. Its the same as a GTE block. No one needs oil squirters with forged pistons. Ask Titan.
