1 - 12 of 12 Posts
· Newbie
Hau said:
check your odometer for loose soldered connections
I have another person's odometer here that I've plugged in and it still doesn't work. It's been working and I haven't done anything to the car so it confuses me. Once in a while still the speedo needle would jump but then nothing.
RedSupra said:
take it toyota
That's a good joke :ugh2: .
· Newbie
E10 2 is the vehicle speed pin right? It's pink and leads to the plug that goes into the odometer? Is there any way to test it? I guess the voltage goes up as the car goes faster causing the speedo to read higher?
But how do I test it, and perhaps run a new line?
· NA-T member
Thats not the problem, Its becasue you jumped wires 5 and 6 in the odometer. You have to cut wire 6 (pink) running to the odometer. The odometer will still work but you are now send a singal into the odometer where it used to be sending one out. You will fry the board if you dont fix it.
· REVTECHRACING.COM
arent you suppose to cut pink and blue/red and tie together to see if then works? i think , not sure, pink is speed in and blue/red is speed out to ecu?
· a supra..fast..hahaha
i'm having a similar problem with my speedo.. it's like when i come to a complete stop the needle slowly returns to zero.. going about 50 and when i come to a stop the needle still reads about 15 and slowly goes back to zero.. ytou have any idea what would cause this?
1 - 12 of 12 Posts
