1 - 18 of 18 Posts
Senior Member
Not realy, it was "2 nighted 3 dayed" from Japan. The brackets will certainly be interesting trying to replicate. The base shouldn't be to hard, but the bar mounting point will be changed abit because it's round.
25psi = 14" brakes :)
So, that bar uses the stock rear hatch gas strut mount?
I'd want one in flat black so you don't get glare off it in your rear view mirror. :)
Nice
Senior Member
Discussion Starter · #14 ·
Don't know what Marcys is.
A rear strut bar and the hatch bar reinforce diffrent areas. I'll have to test with my cusco rear strut out and in same with the hatch bar out and in to tell you what made more diffrence. Maybe I should test with the doluck rxb out also?
I think it will go a long way for stiffening up the chassis. The hatch is one big open area with zero support.
1 - 18 of 18 Posts
