1 - 20 of 22 Posts
Who does this on the forums?
I saw a painted spark plug cover with the lettering in a another color.
I wanted this done.
I PMed blkturbo! but got no response from him.
I thought he did it, but maybe not.
Thanks guys.
SuperMember
any bodyshop can do it if you wanted done right or you can do it yourself it's a no brainer with some spray cans if you feel like doing it
nah rather not do it by spray can style.
I've seen some real nice ones on the forums.
I knew some ppl did it.
Just looking to see if anyone still does.
take it to ANY body shop. theyl coat it with plastic primer, the color you want, then a clear coat. itl cost about 150$ and come with a warranty for show car quality and high temp clear coat. cheaper shops could probably even do a decent job for like 80$.
ELITECUSTOMBODY
what is the color you want? I can do it,but hate dealing with the lettering,I just did one about two weeks ago white with black letters
When I had mine done I had the twin turbo shaved off and just left the Toyota emblem and 2jz-gte on there so one day when I'm single it won't say twin on the spark plug cover.
Never fast enough
i painted my cover i sprayed the color and then with a Q-tip i rubbed the paint of the toyota emblem and the other letter to bring the chrome back out and then i cleared over it. here are some pictures
Headlight Restorer
wait i don't get it....you don't use any chemical such as acetone on the Q-Tip to take the spray can paint off?
ELITECUSTOMBODY
94ttt, did you even prep it?
reguardless how you prep, using scotch pad with prep paste or sanding with 320-400 grit sandpaper, the chrome paint will come off in the prepping process, I actually do both, plus I use a special pen that has thousands of glass strands and use it on and around letters and tight crevices, so sounds to me there was no prep work,
Never fast enough
yes i preped it i used a scotch bright pad and went real easy over the lettering, then i wiped it down with wax and grease remover, then i sprayed it with bulldog, a adhesion promoter and flex adgent. Then i sprayed the cooler and used a Q-tip dipped in the reducer for the paint and rub off the the paint from the letters. After drying i layed the clear. This was not done with a spray can.
Finally single
Im redoing mine right now. Im waiting for the first coat to dry. Im doing something a little different and ill post some pics later.
I fixed the link to mine so it will work now.
1 - 20 of 22 Posts
