feeding your habit
I have an ECU that I believe is a JDM VVTi ecu. Can someone please verify if I post the PN?
ˆê”Ô ƒGƒAƒ�ƒgƒv‚d‚q
Wouldn't it be easier/faster for everyone if you just posted the PN instead of asking if you should post it?
Ishii
feeding your habit
the part number is:
89661-3a470
OR
175200-0684
Thanks!
Mark
ˆê”Ô ƒGƒAƒ�ƒgƒv‚d‚q
I will make it simple, There is only 1 ECU that is for the VVT JZA80 turbo supra '97.8 and up. This ECU has different connectors than you are used to seeing. You can see this on the wiring diagram that I posted ever so long ago.
A search of "vvt" gets you to the link below.
http://www.supraforums.com/forum/showthread.php?t=370519&highlight=vvt
I am only assuming you are hoping to have a 2JZ-GTE VVT computer in your hands which it is not unless the connectors are like in the VVT diagram I linked.
I can try to find out what your part number is, but might take me a while to get around to it.
Ishii
feeding your habit
that appears to be what I have. I don't have the three large connectors as found on the non vvti setup, I have a bunch of smaller connectors, all white (on ecu side).
Thanks - this was very helpful.
Mark
