1 - 9 of 9 Posts
Savage Member
Looking for:
Supra
Clutch master Cylinder
Celica
Driver side control arm; the piece that bolts from right under the wheel hub to the lower control arm. Three bolts in a triangular shaped from control arm to the one bolt at the hub(rotor). It costs approx. 60 $ at my local stealership.
Shipped to 98026
Thanks,
Kyle Ackerman
Savage Member
Rofl
Turbo supra
ST celica
Sorry about that
31410-14193 Cylinder Master List 116.56 Cost 88.79
48643-20030 Lf Lower Arm # 2 List 98.29 Cost 72.68
48069-20160 Lf Control Arm #1 List 179.37 Cost 132.64
43330-29185 Ball Joint List 56.19 Cost 41.55
43212-20061 Knuckle, Lf List 233.18 Cost 172.43
Savage Member
Ok;
Celica (87 ST)
is it possible to just buy the nut that goes onto the bolt which comes off the knuckle? It is 19mm and is ridged and has a hole for a cotter pin.
Supra (87 turbo)
The bolt which holds the CPS in position
Both Hoses for Antifreeze transfer from thermostat to turbo.
Most likely not going to get turbo from you guys; but how much for a stock CT26 turbo?
Umm.. Thats all I can think of for now; as I continue to work I will probably come up with more parts, most likely place an order sometime next week.
Thanks,
Kyle Ackerman
90170-19001 Nut, Hex List 2.40 Cost 1.77
91651-b0825 Bolt, List 0.77 Cost 0.57
16284-42011 Hose, List 13.73 Cost 10.63
16283-42010 Hose, List 16.81 Cost 12.42
17201-42011 Turbo List 2884.88 Cost 2100.00
Savage Member
Curt.. I placed an order from you via e-mail..Everything arrived today; however it seems as if part # 16283-42010 is not the correct hose..
I needed both coolant lines which connect to the turbo.. Maybe I hadn't made it clear.
The part # 16284-42011 is the correct hose.. Maybe there was a mix up w/ the number? I just need the other hose from turbo to wheverer..
I'll ship this one back out tomorrow.
Thanks,
Kyle Ackerman
Edit:::
I just checked cygnus and found it.. I need no. 2 turbo water hose. Also, if you could throw in the gasket that goes between the turbo and the oil feed/drain line.
IF you need me to re-send you the card info and such; just send me a PM.
Savage Member
Curt.. Did you not see this post? Bump just so that you see it.
1 - 9 of 9 Posts
