1 - 20 of 24 Posts
Addicted to boost
Curt,
I just bought a black 92 turbo to keep my MKIV company and it's in need of some restoration. I know this is a long shot, but do you still carry new parts for the MKIII?
Would you say you have
a) a lot of new parts
b) some new parts
c) hardly any new parts
Here's my intial list off the top of my head:
TEMS two button assembly that goes in center console
center console armrest cover assembly (my latch is broken)
leather steering wheel (no airbag)
leather e-brake
leather e-brake pouch
leather 5 spd shift knob
leather 5 spd pouch
left tailight
radio antennae
power steering rack and pinion assembly
targa top key
floormats
carpet kit
power window button assembly (left side)
right mirror
plastic trim pieces that go around lock assemblies (left and right)
I'll stop there... for now :)
Thanks Curt
89249-14010 Switch, Tems List 94.00 Cost 69.51
58905-14070-c1 Console Lid List 89.85 Cost 66.44
45100-14511 Str Wheel List 917.55 Cost 678.50
46201-14181-01 Pb Lever Assy List 105.26 Cost 77.83
46243-14100-13 Pb Lever Boot List 40.53 Cost 29.96
33504-24070-c0 Shift Knob List 103.20 Cost 79.57
58808-14140-01 Shift Boot List 53.44 Cost 41.02
81560-14652 tail light list 206.50 cost 152.48
86300-14372 antenna asss list 214.07 cost 169.20
44250-14181 Rack Assy List 1127.07 Cost 833.07
09168-14010 Wrench, List 19.38 Cost 14.33
09169-14010 Hex Bit List 3.52 Cost 2.60
58510-1b060-13 Carpet Assy Cabin List 996.81 Cost 737.11
570-14350-03 Carpet Assy Hatch List 336.52 Cost 227.00
84820-20200 Master Switch List 224.18 Cost 172.38
87910-1b052-11 Mirror Assy List 219.49 Cost 162.31
69761-14010-03 Bezel, Door List 6.00 Cost 4.44
69762-14010-03 Bezel, Door List 6.00 Cost 4.44
Mkiii Parts Are All Special Order Items Only , If Still Available
Addicted to boost
OK Curt, here's my order!! NOte. some items I would like two of..
Curt Aigner said:
Two of them 89249-14010 Switch, Tems List 94.00 Cost 69.51
Two of them 46243-14100-13 Pb Lever Boot List 40.53 Cost 29.96
Two of them 33504-24070-c0 Shift Knob List 103.20 Cost 79.57
Two of them 58808-14140-01 Shift Boot List 53.44 Cost 41.02
Two of them 09168-14010 Wrench, List 19.38 Cost 14.33
Two of them 09169-14010 Hex Bit List 3.52 Cost 2.60
Two of them 69761-14010-03 Bezel, Door List 6.00 Cost 4.44
Two of them 69762-14010-03 Bezel, Door List 6.00 Cost 4.44
Also, add these to the order....(no quote neccessary)
12 OEM spark plugs
2 fuel filters
2 PCV valves
Also, the plastic "T" that is inline of the small rubber hose and connects to the squirter nozzle on the bottom of the hood, as well as the elbow plastic piece at the end of the line for the driver's side squirter nozzle. Hope my explanation is good enough.
Also, the previous owner had a short throw shifter on the car and I hate it, and I would like to go back to stock, so I need whatever parts required (your best guess) to have the original shifter back in action.
Finally, I need a price quote on following items:
OEM hood shocks
all trim that goes around windshield
all trim that goes around back window
dash (if available, it's going to be hella expensive) :gaysex:
Last but not least (don't need a quote, please order these parts)
This is for my girlfriends 2000 Corrolla VE (don't know the VIN)
PCV valve
4 Denso irridum plugs (I believe these are what OEM calls for)
fuel filter.
Thanks Curt. Much appreciated!!
James O
33530-14390 LEVER SHIFT LIST 140.47 COST 103.87
85348-14390 JOINT, T LIST 2.23 COST 1.65
85355-14481 JOINT, ELBOW LIST 2.31 COST 1.80
53440-19035 SUPPORT HOOD LIST 88.23 COST 68.12
53450-19035 SUPPORT HOOD LIST 88.23 COST 68.12
75531-14150 MOULDING,TOP WS LIST 43.87 COST 32.44
75533-14170 MOULDING,RH WS LIST 30.75 COST 22.74
75534-14140 MOULDING,LH WS LIST 30.75 COST 22.74
75535-14210 MOULDING,BOTTOM WS LIST 220.18 COST 162.82
75571-14190 MOULDING,TOP LIST 77.88 COST 60.17
75574-14172 MOULDING,LH LIST 72.08 COST 53.30
75573-14202 MOULDING, RH LIST 72.08 COST 53.30
75575-14170 MOULDING,BOTTOM LIST 93.34 COST 69.03
55401-14490-13 DASH LIST 926.49 COST 685.11
90919-01145 PLUG, SPARK LIST 8.52 COST 6.29 EA
23300-49155 FILTER FUEL LIST 38.75 COST 28.66
12204-22051 VALVE LIST 4.90 COST 3.62
23300-0D010 FILTER FUEL LIST 32.87 COST 24.77
90080-91184 PLUG, SPARK LIST 10.37 COST 7.65 EA
Copy and paste all of the items that you need into a e-mail to me. Include your name address phone number and CC info.
Addicted to boost
Discussion Starter · #11 ·
Will do. Last question. Are the parts I quoted for the Supra or the Corolla?? If Corolla, you missed the PCV for the Supra. Let me know. Thanks.
Addicted to boost
Discussion Starter · #17 ·
Curt, I received my second shipment. Thank you!
Of the parts listed, are the first 3 for the windshield and the rest for the back window??
Addicted to boost
Discussion Starter · #19 ·
Looking at the windshield trim more closely, it appears that there are 5 pieces total.
1 long piece across the top
2 sides
2 corner pieces at the top of the windshield.
With that said, it seems that the corner pieces have been excluded from your parts list??? :scratch:
1 - 20 of 24 Posts
