1 - 8 of 8 Posts
Function over form
I am in need of the following parts for the 2JZ-GE:
Whatever gaskets and O rings are needed to service the oil filter bracket that the oil filter screws on to. I think my huge oil leak is coming from that area.
The little plastic brackets that hold the spark plug wires in the spark valley all the way to the distributor. There are several of them that are used to keep the wires aligned properly all the way from the #6 plug to the distributor cap. Some of them are little white brackets and some are black.
The 2 metal gaskets used on the intake between the throttle body and the Y plenum and between the Y plenum and the runners.
Please get back with me at your earliest convenience. Thank you!
90430-20016 gasket bolt list 1.72 cost 1.32
90301-68005 ring, o list 4.80 cost 3.66
90929-01278 clamp list 2.43 cost 1.85 ea x 2
90929-01277 clamp list 3.32 cost 2.53
19941-46010 clamp, list 9.37 cost 7.16
90929-01280 clamp list 2.43 cost 1.85
90929-01285 clamp list 2.43 cost 1.85
19949-50010 clamp, list 2.63 cost 2.01
[ clamps special order 3-5 days ]
22271-46020 gasket, tb list 4.52 cost 3.44
17849-46020 gasket, y pipe list 7.09 cost 5.41
17176-46020 gasket, plenum list 12.14 cost 9.27
Function over form
Thanks! I will e-mail you later today with payment information.
Function over form
sorry for delay will send funds tonite after work
Function over form
got these in the other day. thanks so much! i'm sure i'll need something else sooner or later.
1 - 8 of 8 Posts
