1 - 11 of 11 Posts
I Can Has EBT?
hey there. I am looking for following parts for 1994 Supra TT.
Rear main seal and pilot bearing. ( I am installing a tranny and need to replace all worn out parts in there.
Also need a braket for 6 speed console. part # 33555-14110.
I will also need following parts.:
31321-14020 pedal pad list 3.23 cost 2.39
58261-14010 upper trans tunnel list 78.54 cost 58.08
31321-14020 brake pedal pad list 3.23 cost 2.39
79191-00672 75w90 Castrol gear oil list 13.95 cost 10.15 x 2
55107-14140 support assy list 69.76 cost 51.80
58994-14010 console bracket list 6.74 cost 5.01
Do you want me to call in for the order?
Thanks, Daniel S.
90311-90006 Seal, Rm List 36.87 Cost 27.26
90363-12002-77 Bearing,pilot List 9.36 Cost 6.92
33555-14110 Boot, List 32.81 Cost 24.26
You can call me or use e-mail. If you use e-mail I need your name,address,phone number and CCinfo and items requested.
I Can Has EBT?
Hey Curt, I called in and ordered the above parts plus v160 fluid, but I noticed that I already have the boot part # 33555-14110 Boot, List 32.81 Cost 24.26. I hope it is not too late to alter my order. If you already shipped the item, do you accept returns?
Thanks, Daniel
I Can Has EBT?
Discussion Starter · #6 · (Edited)
I am sending back part # 33555-14110 Boot, List 32.81 Cost 24.26.
I will need additional parts:
31311-14120 clutch pedal list 42.18 cost 31.32
47101-14230 brake pedal list 49.67 cost 36.88
31410-14310 master cylinder list 99.39 cost 73.49
90386-08010 bushing list 5.37 cost 4.00
31353-14010 holder list 3.34 cost 2.47
96160-00600 e ring list .63 cost .47
Also need a price check for this part. 31402 . It is a reserviour for the clutch master cylinder.
31410a x 2 (the bolts that holds the master Lylider)
31417
31402e
The parts are marked in the pic here.
90949-03013 spring list 11.40 cost 8.47
90949-03011 spring list 1.93 cost 1.43
I take it that the 2 springs are from the clutch assmebply as listed on this pic. I need the 2 for the clutch pedal assembly.
Do I need to call in or you can just bill the same info you have from the previous order?
Thanks, Daniel S.
31311-14120 Pedal,c List 44.18 Cost 32.67
47101-14230 Pedal,b List 51.81 Cost 38.31
31410-14310 Cylinder Assy List 104.16 Cost 77.02
90386-08010 Bushing List 5.60 Cost 4.15
31353-14010 Holder, List 3.46 Cost 2.56
90082-61005 Ring, E List 1.60 Cost 1.18
31402-24030 Reservoir List 30.46 Cost 23.33
90116-08146 Bolt, List 0.69 Cost .50 Ea X 2
31417-35010 Grommet, List 2.00 Cost 1.54
96151-02200 Ring, List 1.63 Cost 1.21
90254-05009 Pin, List 0.80 Cost 0.59
94120-40800 Nut List 0.74 Cost 0.55
90949-03013 Spring, List 11.89 Cost 8.79
90949-03011 Spring, List 2.04 Cost 1.51
Filter Thru This List And Shoot Me A E-mail Of What You Need.
I Can Has EBT?
Just emailed you.
I want following parts.
Please bill cc from last mondays order.
thanks, Daniel S.
I Can Has EBT?
Discussion Starter · #10 ·
Will I receive the parts by Friday and do I still need to call in?
Thanks.
1 - 11 of 11 Posts
