I would like the part numbers and prices of a few parts for my '89 Supra Turbo. I will do my best to describe each item.
1. Outer tie rod (front passenger side)
2. Oil Bypass Hose from the head (near the alternator) down to the block. (About 7/8" diameter)
3. Exhaust Manifold Gasket (between manifold and head)
4. Gasket between turbo and exhaust manifold
5. Gasket on the bottom of the turbo that connects to the oil feed and return lines
6. Exhaust manifold studs (connect to head)
7. Nuts for Exhaust Manifold Studs
-I believe there are seven studs and bolts required to tighten the exhaust manifold, but please check so I order enough
-Also, I don't know if you can get the connector and wire that attach to the oil pressure sender unit, but please let me know.
I hope that all made sense. If not, just let me know and I will try to describe it better. Thank you as always.
