1 - 16 of 16 Posts
Hi Curt,i would like to get parts quate for the following+shipping price to Canada Montreal:
Flywheel Bolts 90910-02115 x8
Pilot bearing 90363-12002-77
Snap Ring 96152-00500
T/O Bearing 90903-63001
Snap Ring 90560-50001
Spacer 90560-79001
Wave Washer 90206-12006
Snap Ring 90520-75001
Spring 31264-14060
Clutch Release Hub 31231-14050
Pressure Plate Bolts 90119-08079 x6
Rear Main Seal 90311-90006
Fork Parts:
Fork 31204-14060 inc (ABC)
Bolts 90119-10054 x2
Fork Spring 31234-14020
Support Release Fork 31236-14030
Clutch Hydraulics
Slave Clutch Cylinder 31470-14060
Bolts 91611-60825 x2
Tube 31482-14050
Bracket Flexible Hose 31484-24010
Hose clip 96991-10080 x2
Bolt 90119-06733
TRD Transmission Mount
Discussion Starter · #11 · (Edited)
Hello Curt, i need a quote for the following parts included shipping to
to 9147 15e Ave Apt.4 H1Z 3P2
Montreal Quebec Canada
[email protected]
85192-12020 x2 Cover For wiper arms
90179-08113 x2 Bolts
+2 wipers with rubber Summer
90467-08056-CO x2 Clip,
90164-40096 x5 Bolts
90189-04218 x5
90189-04208 How many clips supposed to be?
53383-14120 x1 Does it come with 90467-10146 x12? if yes i take 'em
90541-15004 x2 Hood Absorder
90119-06352 x12 Bolts for fenders
53882-16030 x6 Fender seals for Upper bolts
53878-50010 x4 Front Fender Spacer
90105-06152 x4 Bolts that goes through the spacers
93385-56020 x1 Bracket bolt
90119-06311 x1 Upper bracket bolt
52115-14130 x4 Support for headlights
74531-20060-22 x2 Hook For the rear Plastic
90159-40049 x2 Screws
90980-10871 x1 Housing
82998-12340 x1 Terminal
90119-06612 x4 bolts for upper reinforcment
91651-60614 x4 bolts for upper reinforcment
52521-14090 x1 Retainer, front bumper upper center
53395-14010 x1
90467-08044 x2 if its not included in part 52521-14090 ?
90467-09093 x5
90981-11018 x1 Bulb
83101-14040 x1 Socket
68710-30150 x1 Upper Door Hinge
68730-30120 x1 Lower Door Hinge
90105-10342 x4 Bolts For the door
90105-06170 x2 Bolts for the door
Thanks you
Discussion Starter · #15 ·
Hi Curt,
I need a Quote please
89542-14030 x1 Front Right ABS Sensor
22271-46030 x1 Gasket Throttle Body
90179-08153 x2 Bolts
91511-80840 x2 Bolts
16261-46040 x1 Hose
16264-46060 x1 Hose
90467-13050 x2 Clamps for water bypass #1
90467-13050 x2 Clamps for water bypass #2
90119-06388 x6 Bolts
69410-30040 x2 Lock Striker
69415-30010 x2 Cover for Lock Striker
90901-48001 x4 Bolts
76671-14020 x6 Clip Quater Vent Duct
90467-05042 x4
90467-09053 x4
90179-05086 x6
90164-40085 x6
1 - 16 of 16 Posts
