1 - 20 of 117 Posts
2007 FSAE World Champion
Curt,
I have a 92 MK3 and need the following prices on the parts -If ordered they will be shipped to 53726 and will be needed asap.
7mgte motor still
Water outlet to head Gasket (triangular shape, three bolts)
Bolt for said housing to head for rear most hole (closest to cylinder 1)
Rubber turbo coolant hoses (in and out)
Rubber elbow coolant hose under water outlet housing
thermostat
thermostat gasket
radiator cap
Cam position sensor O-Ring
This car is currently torn apart and is my DD so I need the parts ASAP, I will let you know later today what I am going to order depending on how fast I can get it. I will also check the local dealers to see if by chance if they have the parts since I want to get it back on the road as quickly as possible.
Thanks Curt!
Dave
Super Moderator
I can have them there wednesday/ thursday.
16343-42020 GASKET, LIST 3.12 COST 2.37
91611-60835 BOLT, LIST 1.57 COST 1.21
16284-42011 HOSE, LIST 16.34 COST 12.47
16285-42010 HOSE, LIST 8.97 COST 6.85
16283-42010 HOSE, LIST 19.11 COST 14.59
90916-03078 THERMOSTAT LIST 14.69 COST 11.21
16341-35010 GASKET, LIST 2.31 COST 1.77
16401-72090 CAP LIST 13.34 COST 10.19
90099-14088 O-RING 166 9 1.41 2.34 1 1.79
Discussion Starter #3 (Edited)
Curt,
Please send me the tracking number once the order has shipped out, also if you can send me the torque spec for 91611-60835 BOLT, LIST 1.57 COST 1.21, the water outlet to head bolt I would appreciate it since the TSRM does not have a spec.
Thanks,
Dave
Discussion Starter #5 (Edited)
Curt,
Thanks for the tracking and getting those parts sent out so quickly, I can't wait to get the car back on the road! I may have another order for you though.
17882-42012 - accordian pipe
compressor to wastegate actuator vac line
Also what is the cost per foot of the assorted vac line sizes on the 7m-gte? I am looking to replace all the Vac lines this summer and would be happy to buy the bulk lines from toyota and cut it to length. If you know the sizes and an approximate overall length that would be awesome.
lmk and thanks again you guys rock!
Dave
Super Moderator
17882-42012 Hose, Intake List 53.02 Cost 40.47
17294-28010 Hose, Actuator List 9.03 Cost 6.90
90999-92008 Hose, Vacume Line In 2600mm Lenght List 42.13 Cost 32.17
[cut To Size Needed ]
Curt what would be the approx total with the 2 above parts and the following parts including shipping.
92 turbo 5spd parts
Steering stop bolt, nut and plastic covers - both sides
ISCV vac hose's (both sides of the motor)
ISCV gasket
Front A-arm clips to hold ABS line - both sides
PCV vac hoses - all of them
CT26 wastegate actuator
transmission mount
engine oil dipstick
CPS cover : part #19121-42010 $4.13
Dust seal (gasket) : part#19127=42010 $1.97
98 supra turbo motor mounts - both sides
Shipping would again be to 53726
Thanks,
Dave
Super Moderator
45619-14020 Cover,cap List 4.57 Cost 3.49 Ea
90106-10002 Bolt, List 1.34 Cost 1.03
16261-42010 Hose, Iac List 19.28 Cost 14.72
16264-42040 Hose, Iac List 29.10 Cost 22.23
17347-42010 Hose, IAC List 19.32 Cost 14.76
22278-42010 Gasket, Iac List 2.77 Cost 2.12
96991-10080 Clip Line List 1.34 Cost 1.03 Ea X 2
12264-42010 Hose, Vent List 16.72 Cost 12.76
12261-42010 Hose, Vent List 3.92 Cost 2.98 Ea X 2
12262-42010 Hose, Vent List 14.05 Cost 10.73
12263-42010 Hose, Vent List 34.50 Cost 26.34
12371-42020 Insulator Trans List 73.45 Cost 56.08
15301-42012 Gage List 15.52 Cost 11.85
16343-42020 Gasket, List 3.12 Cost 2.37
90099-14088 O-ring List 2.34 Cost 1.79
19121-42010 Cover, List 5.57 Cost 4.25
19127-42010 Packing, List 2.86 Cost 2.18
12360-46111 Insulator Engine List 76.11 Cost 58.12
CT26 wastegate actuator/ NOT SOLD SEPERATELY FROM A NEW TURBO ASSY.
Ups Ground Add 10.00 / Some Items Special Order 1-2 Days
Discussion Starter #9 (Edited)
Curt lets go ahead and get this sent out. Do you want me to call to place the order? I will be using the same CC as the order I placed last week so you can use that number if you still have it.
Also the steering stop bolts, lock nuts and plastic covers, lines 1 and 2 I beleive, I will need for both sides.
Thanks again for all your help.
Please ship to
Dave Hanna
105 Lathrop St.
Madison WI 53726
Thanks,
Dave
Discussion Starter #12
Curt I need the first two items.
Thanks.
Super Moderator
OK I'M SHIPPING THIS:
45619-14020 Cover,cap List 4.57 Cost 3.49 Ea X 2
90106-10002 Bolt, List 1.34 Cost 1.03 X 2
96991-10080 Clip Line List 1.34 Cost 1.03 Ea X 4
12360-46111 Insulator Engine List 76.11 Cost 58.12 X 2
Discussion Starter #14
Can you send me the total and tracking number once it ships?
Thanks,
Dave
Discussion Starter #16 (Edited)
Curt,
Just received the parts today and noticed one thing. I guess I wasn't very clear on these and its my fault for not knowing the part number on them, but I was not looking for the brake line clips but for the abs sensor line clips which attach the sensor wire to the a-arm. Either way I will take what I received and replace whats on the car when the time comes but I really need the ABS sensor clips which attach to the upper a-arm.
So here is the list of things I would still like.
Front A-arm clips to hold ABS sensor wire - both sides
90341-18019 Plug, List 6.52 Cost 4.98
Also thanks for all the in depth drawings they are very helpful and I have the TSRM for the car.
Thanks,
Dave
Discussion Starter #18
Curt,
Couple more items I am interested in.
92 turbo 5spd
Upper control arms - both sides
Clutch inspection cover gaskets - both sides
98 turbo
motor mount nuts - this is to install into the 92, I noticed the nuts are not the same, if you could let me know how much new nuts and washers are and the part numbers you recommend when putting in the newer mounts I would appreciate it
Thanks,
Dave
Super Moderator
48610-19015 Arm Assy,rf Upr List 492.57 Cost 376.09
48630-19015 Arm Assy,lf Upr List 492.57 Cost 376.09
31102-14010 Cover Rh List 82.57 Cost 63.04
31101-14010 Cover Lh List 82.57 Cost 63.04
90179-12153 Nut, Upr List 1.32 Cost 1.00 Ea
90179-14055 Nut Lwr List 1.57 Cost 1.21 Ea
Discussion Starter #20
Curt,
Do the clutch inspection cover gaskets not sell seperately? Do you have to purchase the cover?
Also do you have a diagram of all the parts available for the accelerator pedal? Mine has a bit of play in it and I would like to replace any parts which are known to wear out over time. A diagram would help me determine what is all involved.
Thanks,
Dave
1 - 20 of 117 Posts
