1 - 8 of 8 Posts
2007 FSAE World Champion
Guys,
I have a 92 MK3 and need the following prices on the parts -If ordered they will be shipped to 53726 and will be needed asap.
7mgte motor still
Water outlet to head Gasket (triangular shape, three bolts)
Bolt for said housing to head for rear most hole (closest to cylinder 1)
Rubber turbo coolant hoses (in and out)
Rubber elbow coolant hose under water outlet housing
thermostat
thermostat gasket
radiator cap
Cam position sensor O-Ring
This car is currently torn apart and is my DD so I need the parts ASAP, I will let you know later today what I am going to order depending on how fast I can get it. I will also check the local dealers to see if by chance if they have the parts since I want to get it back on the road as quickly as possible.
Thanks guys!
Dave
Discussion Starter #2
Parts ordered, please omit
Mike,
What would be the approx total of the following parts including shipping.
92 turbo 5spd parts
17882-42012 Hose, Intake List
17294-28010 Hose, Actuator List
Steering stop bolt, nut and plastic covers - both sides
ISCV vac hose's all of them
ISCV gasket
Front A-arm clips to hold ABS line - both sides
PCV vac hoses - all of them
CT26 wastegate actuator
engine oil Dipstick
transmission mount
16343-42020 GASKET, LIST 3.12 COST 2.37
90099-14088 O-RING 166 9 1.41 2.34 1 1.79
CPS cover : part #19121-42010 $4.13
Dust seal (gasket) : part#19127=42010 $1.97
98 supra turbo motor mounts - both sides
Shipping would be to 53726
Thanks,
Dave
any update on the cost of the above list?
I ended up purchasing the parts elsewhere. Thanks for your help though.
Dave
1 - 8 of 8 Posts
