1 - 20 of 26 Posts
OG SF Member #603
Is this the correct part # and price for the 6spd shock absorber that connects to the tension pulley?
16602-46010 shock absorber list 62.56 cost 46.26
Thanks.
Scott
OG SF Member #603
Curt,
I need a new sensor. There are 2 sensors on the waterneck. I need the top one when the neck is installed. For a '94 TT 6spd.
Thanks.
83420-aa010 Water Temp Sensor List 22.66 Cost 17.03 single wire
89422-35010 Sensor, Efi Temp List 57.07 Cost 42.89 double wire
OG SF Member #603
Curt,
Can you send me the shock absorber. I know mine is around here somewhere, but I can't find it
I also need the gasket for the waterneck to block connection. I don't need the sensor, I found it:)
So, just the shock absorber and the gasket.
Thanks.
Scott
OG SF Member #603
Curt, got the order...thanks.
Next up...
I need the 2 gaskets for the air intake pipes into the compressor blades for the stock turbos. Not the pipes going into the compressor housing, but into the blades.
I also need the front(egcv) O2 sensor. Does it come w/ the wire and plug?
Thanks.
OG SF Member #603
Discussion Starter · #11 ·
Curt,
Is it possible to buy just the O2 sensor connector? I have the sensor and the wire, but no connector.
Thanks.
OG SF Member #603
Discussion Starter · #13 ·
Curt,
Forget the O2 sensor, I picked up a used one locally.
But.....I'm going to bite the bullet and pick up a new '93-'95 TT 6spd wiring harness. What's the damage and is it in stock?
Thanks.
Scott
OG SF Member #603
Discussion Starter · #15 ·
Curt...still compiling my list...lol.
I believe it's called the power steering reservoir. The silver container w/ the black lid. I need one.
Thanks.
OG SF Member #603
Discussion Starter · #17 · (Edited)
Bolts that hold the clutch to the flywheel.
Bolts that hold the Getrag bellhousing to the block.
New coil pack connectors, pins, insulators, etc. Whatever is needed to repair the wiring harness connectors that connect to the coil packs. I will need at least 2.
Thanks.
90119-08079 Bolt, List 0.49 Cost 0.36 Ea X 6
90080-11426 Bolt List 1.74 Cost 1.31 Ea X 5
90119-10260 Bolt, List 2.66 Cost 2.00 Ea X 4
90980-11246 Connector List 5.89 Cost 4.43 Ea X 6
82998-12440 Terminal, List 5.32 Cost 4.00 Ea X 12
OG SF Member #603
Discussion Starter · #19 ·
Curt,
Can you ship me the following items? Thanks.
1 - 20 of 26 Posts
