1 - 4 of 4 Posts
Just fixed my window switch and thought I'd share. Couple things to help get started:
  • Check out Faye's video for some good visuals. She swaps it out for a part that I wasn't able to get anymore though
  • This part does work as a replacement and is the easiest path. I actually got one of these but I'm an idiot and had the window lock on and thought it didn't work so I ended up fixing my original. The harness plug fits kind of loose in it but should be ok considering it doesn't really move
  • Get yourself some long, very thin screw drivers or picks. Ones for working with electronics or taking apart consoles/game pads should work well
First remove the handle out of the door. Push the notches on the long sides in with a screwdriver to get the switch out.
Bumper Automotive exterior Automotive tire Gas Electrical wiring
Next part is by far the most difficult, and the one Faye calls out in her video I believe. Note, before removing it make sure to put a mark on one side on the chassis and plug (white plastic) so you know which way it goes back together. The fitment on the plug to the switch chassis is VERY tight. I used a small plastic blade/prybar used to take apart consoles and game pads to pop one side up over the notch on the plug. Then I stuck two of the small screwdrivers in there on either side of the notch to open up a channel and keep it open (if you don't it'll snap back down when you work on the other side). Repeat on the opposite side (it'll be an even tighter fit) and I used some pliers to pull it out. Took a pretty good amount of force to get it moving but once the notches clear you're good to go.
Engineering Office supplies Electronic device Electrical wiring Machine
Here's a shot of it apart. The only problem was corrosion on the grounding contacts of the switch, that's it. I scrubbed all the metal bits with IPA and a toothbrush, tested continuity with a multi-meter, reassembled and was good to go.
Gas Electronic component Cable Machine Electronic engineering
During reassembly the little copper pieces can only go in one way (one side is smaller) so don't fret if they fall out and you didn't catch how they were placed.
Auto part Metal Nickel Engineering Font
Wood Lego Toy Toy block Art
Super simple fix it's just a PITA to separate the chassis from the plug.
Quality post
These are the same switch internals that Toyota has used on a variety of models, with changes to the switch part you touch for each model. Though in some cases even these are identical! We have two LandCruisers, a Supra and an LS400 and all the internals are this same copper rocker. Just use contact cleaner to remove the carbon buildup, perhaps some super fine sandpaper to remove pitting on the contacts, and reassemble the way you found it/them. Kind of a blessing Toyota went with these large, disassemble-able switches, vs competitors with tiny sealed micro switches (cough Audi...) that die and you cannot even open them up. We're pretty lucky compared to other makes..
1 - 4 of 4 Posts
