1 - 10 of 10 Posts
Hey guys
Those of you who have installed a 3-row, are there any extra spacers on the top where the 2 bolts are or only those that are welded on? If there are spacers could you please tell me how big they are.
Then do you have to remove the hood latch cover on the bollom of the latch on the right side since my fm is bumping against that and will not let me come all the way up.
Thanks guys
I'll try tomorrow and hopefully it'll go with no probs.
I had so much problems with my FMIC piping lining up. I did have to use a spacer on the bolts you are referring to. I used 1/4" on both sides.
Dont get me wrong the Greddy 3 row fit in great if you wanted the drivers side i/c piping dragging all over the road. Had one custom made. Solved all my problems I was having last summer.
The cover has to be removed, not hammered, i mean it's one philps head screw. The is actually one spacer included in the kit and that goes on the tab centered on the top of the intercooler so it does not bend when you tightin the bolt fastening it to the headlight support.
-Carl-
I removed the cover and it fits perfectly, Only thing is I think I'll have to cut off a small tab on the left side to let the piping go through with no problems. My left endtank is rubbing a bit against the frame but it has been rebuilt and is not a big deal.
1 - 10 of 10 Posts
