·what does your greddy A/F read under full boost 4th gear or higher? where do you guys mount your O2 sensor at?
thanx
Jonas
thanx
Jonas
Under full boost, the gauge should be pegged all the way to the right (8.0?). At least mine did.what does your greddy A/F read under full boost 4th gear or higher?
Top of the DP, just below the flange.where do you guys mount your O2 sensor at?
That's what mine does too. Iv've been told that it's not right though. Those things are extremely inaccurate. I don't think the car would even run right if it was truly running that rich.Monkeyman said:Under full boost, the gauge should be pegged all the way to the right (8.0?). At least mine did.
I had Greddy. It even says in the manaul......Zerosoul said:8:1 is crazy rich! what kind of A/F monitor device are you using? is it a wideband?
Curt Aigner said:
list of stuff I did for winter project :
ENGINE-
HKS EVC-EZ
HKS TURBO TIMER TYPE O
HKS POLISHED INTAKE PIPE W/STAINLESS STEEL CLAMPS
HKS VPC
HKS GCC
HKS SS-BOV
HKS FMIC GT W/POLISHED PIPES &T-BOLT STYLE CLAMPS
HKS SUPER MEGA FLOW A/F
HKS SLD
HKS FCD
TOYOTA TUNDRA OIL COOLER FOR POWER STEERING PUMP
PHR DRIVE BELT ILDER PULLEY IN BILLET ALUMINUM
UR RACING CAM GEARS
UR RACING CRANK,PS,WP,ALT PULLEYS
RMM DOWN PIPE WITH O2 SENSOR #2 AND A/F RATIO SENSOR,EGT PROBE
TRD EXHAUST GEN 2
PHR FUEL DAMPER LINE BY-PASS
FUEL PUMP 9V TO 12V CONVERSION
PHR UPPER RADIATOR PIPE POLISHED RED JOINT HOSES/STAINLESS STEEL CLAMPS
JACKSON RACING IC JOINT HOSES IN RED/T-BOLT CLAMPS
MANUEL ELECTRIC COOLING FANS BY- PASS SWITCH
SEQUENTIAL>TRUE TWIN TURBO BY-PASS SWITCH
MISC CHROME PARTS UNDER HOOD:HOOD PROP/RADIATOR BRACKETS/BATTERY HOLD DOWN/STB NUTS/INJECTOR RELEY COVER
VALVE COVER,TIMING COVER CUSTOM CUT FOR CAM PULLEYS-PAINTED SILVER LETTERED IN RED
REDLINE WATER WETTER {COOLING SYSTEM}
HOSE TECHINIQUES RED VACUME LINE 3MM & 6MM
MOHED POLISHED RADIATOR PANEL
TRD RADIATIOR CAP
TRD OIL CAP ALUMINIUM
NIPPONDENSO IRRIDIUM PLUGS {6}
INTERIOR MODS:
H-R AUTOMOTIVE INDGLO GAUGE FACES BLUE
PH RACING DUAL A PILLER POD
APEXI-EGT GAUGE 60MM WHITE FACE EL BLUE
APEXI-BOOST GAUGE 600MM WHITE FACE EL BLUE
GREDDY A/F RATIO GAUGE WHITE {IN CLOCK LOCATION}
RAZZO ALUMINUM PEDAL PADS {4}
AREOSPEED FLOOR BRACE MOUNTED BETWEEN SEAT BELT ANCHORS PAINTED SILVER
TRD JAPAN STEERING WHEEL/WITH AIR BAG
B & M SHORT THROW SHIFTER
FACTORY DASH BEZELS PAINTED SILVER TO MATCH GAUGE BEZELS
SUSPENSION MODS:
TRD FRT STRUT TOWER BRACE PAINTED SILVER
CUSCO REAR STRUT TOWER BRACE PAINTED SILVER
AREO SPEED FLOOR BRACE PAINTED SILVER
TRD SPRING KIT F & R
TRD STRUT KIT F & R
TRD SWAY BAR KIT F & R
BRAKE MODS:
TRD FRT PADS
TRD REAR PADS
GREDDY SS BRAKE LINES
SILICONE BRAKE FLUID
BODY MODS:
RMM CARBON FIBER 3PC WING PAINTED BLACK
TRD RACING STICKERS
CUSTOM FRONT GRILLE W/CUT-OUTS FOR PIAA DRIVING LAMPS
PIAA 100WT FOG BULBS
PIAA 100WT HIGH BEAM BULBS
PIAA 80WT LOW BEAM BULBS
PIAA ALL OTHER EXTERIOR BULBS IN SUPER WHITES IE:TAIL LIGHTS RUNNING LAMPS,TURN SIGNALS ETC.
EURO STYLE HOOD SCOOP{ FUNCTIONAL}
RMM FRONT POLY-LIP SPOILER
TOYOTA BLACK CHROME LISCENCE PLATE FRAME
