1 - 14 of 14 Posts
Does anyone know where performance radiators for the MK11 can be found? It seems everywhere I have looked they provide them for 1996 and above only.
i wasn't sure if they were different, so i just said turbo cuz i knew it would be better. still wondering if the mk4 one will fit though since SilverMK2 suggested it.
2JZ Mk2
Supra_devil said:
does the mk4 one work? i've thought they were to wide for the frame rails.
When I bought my CSF I asked about the Mk4 one and they said its the same core size as the Mk3 one. The only difference is the tanks and the outlet locations. Looking at the shape of the Mk4 on it looks like a better fit.
greasemonkey
Robbman said:
No difference between a Mk3 turbo and a Mk3 NA radiator.
The clutch fan was different, and is cheap upgrade for more airflow on a 5M/6M/7M-GE
you sure the fanclutch was diff. thought they were the same part number. i know the fans were diff. turbo had 10 blades instead of 7.
Discussion Starter · #13 ·
MKII performance radiator.
So am I understanding correctly that both the MK3 and MK4 performance radiators will fit in my 85 MKII ?
1 - 14 of 14 Posts
