1 - 4 of 4 Posts
I just installed a Philip Long 2-Step and it seems to be working correctly, however the stutter speed seems slow. It seems to be stuttering about 1 to 2 times a second, which seems slow compaired to when I hear other cars with 2-steps.
This was with the 2-step set for only about 4k rpms. I attempted to adjust tje trim pot but if I go any higher it won't 2-step at all, as it will just rev past the 2-step limit.
Is the slow stutter speed normal for this unit?
Thanks!
its normal, but there is a little adjustment spot on the unit where you can take a small flat screwdriver and mess around with it, unless that is what you are calling the trim pot or whatever. Try that and see if you havent already.
Also the higher the rpm you set it the more boost you tend to build with it.
Also keep in mind this is a different type of 2 step. The ones you hear like rapid firing amo are anti-lag/2 step in the aem or other stand alone systems.
Moderator, l337 M0d3r4t0r
yes this only cuts ignition signal vs the rest mess with ignition timing ect to make it stutter real fast
1 - 4 of 4 Posts
