Currently if I have either the red wire or the black wire going to the 2-step connected the car will not start at all...if I disconnect both the black and red wire the car starts and runs fine.
The white wire is going to the ECU and the Green whire is going to the harness as well as the AFC and the VPC. When the car is started the AFC shows RPM good and the car starts so I don't think that there could be a wiring issue there...and also if the White wire was not connected the car would probably not start at all.
Does anyone have any input on this situtation. Your help is very appreciated. Thanks
