1 - 3 of 3 Posts
Hi
I have an 850 hp supra, I bought a 3.5 phr driveshaft, it came only with 4 bolts which connect the aluminum adapter to the drive shaft.
- How can I connect the driveshaft to the transmission ??
Is it ok to use OEM bolts ??
Thank you
Hi
Thank you
Phr uses the factory rubber piece. The adapter and 4 bolts are for the d/s to transmission connection.
Is there a problem if I use the Oem bolts ?
Are they powerful enogh to withstand the hits
of an 850 hp ??
1 - 3 of 3 Posts
