1 - 20 of 27 Posts
PHR's Black Friday Sale is in full swing.
CLICK HERE TO SEE THE SALE
Here's the list of our Black Friday Sale items for the Supra:
Brake Upgrades
PHR Trac Pump Delete Kit (including Motul RBF600) $52.00
PHR Stainless Brake Line Kit for Supra Twin Turbo Calipers $119.00
PHR Stainless Brake Line Kit for Supra Non-Turbo Calipers $119.00
PHR ABS Delete Kit for Supra $239.00
PHR ABS Delete Kit for Supra with Line Lock $391.00
Cooling System Upgrades
PHR IS300 Fan Shroud ONLY (NON POLISHED) $356.25
PHR Polished Radiator Pipe, Blue $99.00
PHR Polished Radiator Pipe, Black $99.00
PHR Polished Radiator Pipe, Red $99.00
PHR Lower Waterneck Flange Adaptor (Rotator) for 1993-98 Supra $64.00
PHR Modified Lower Waterneck w/ 20AN Fitting $84.00
PHR Billet Race Waterneck (Fits Large Frame Turbos) $239.20
PHR Billet Race Waterneck (Fits Large Frame Turbos), Polished $311.00
PHR Billet Race Waterneck w/ 20AN Outlet (Fits large frame turbos) $239.20
PHR Billet Race Waterneck w/ 20AN Outlet (Fits large frame turbos), polished $311.00
PHR Race -20AN Radiator Hose Kit for 93-98 Supra TT - Includes PHR Billet Race Waterneck, w/ -20AN oultet, PHR Modified Lower Waterneck w/ -20AN Fitting, Upper and Lower Radiator Hoses (Stainless Braided w/ Teflon Core, -20), 2x -20AN Aluminum Weld-on Bosses for Radiator. Not for use with factory fan shroud. Must use electric fans $927.00
PHR Race -20AN Radiator Hose Kit for 93-98 Supra TT - Includes PHR Billet Race Waterneck, w/ -20AN oultet, PHR Modified Lower Waterneck w/ -20AN Fitting, Upper and Lower Radiator Hoses (Stainless Braided w/ Teflon Core, -20), 2x -20AN Aluminum Weld-on Bosses for Radiator. Not for use with factory fan shroud. Must use electric fans (BLACK HOSES) $927.00
PHR Race -20AN Radiator Hose Kit for 93-98 Supra TT VVT-i - Includes PHR Billet Race Waterneck, w/ -20AN oultet, PHR Modified Lower Waterneck w/ -20AN Fitting, Upper and Lower Radiator Hoses (Stainless Braided w/ Teflon Core, -20), 2x -20AN Aluminum Weld-on Bosses for Radiator. Not for use with factory fan shroud. Must use electric fans $927.00
PHR Race -20AN Radiator Hose Kit for 93-98 Supra TT VVT-i - Includes PHR Billet Race Waterneck, w/ -20AN oultet, PHR Modified Lower Waterneck w/ -20AN Fitting, Upper and Lower Radiator Hoses (Stainless Braided w/ Teflon Core, -20), 2x -20AN Aluminum Weld-on Bosses for Radiator. Not for use with factory fan shroud. Must use electric fans (BLACK HOSES) $927.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Black Hose Ends, Stainless Line $379.00 $341.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Black Hose Ends, Stainless Line, VVT-i $341.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Red/Blue, Stainless Line $341.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Red/Blue, Stainless Line, VVT-i $341.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Black Hose Ends, Black Line $341.00
PHR Do-It-Yourself 20AN Radiator Hose Kit - Includes Hose, Hose Ends and Weld bungs to assemble -20AN upper and lower radiator hoses. Black Hose Ends, Black Line, VVT-i $341.00
PHR Dual Extreme-Duty Spal Fan Shroud, Shroud Only $159.00
PHR Dual Extreme-Duty Spal Fan Kit $593.00
Powdercoat (Select Color) $90.00
Polished $180.00
Electronics
PHR Resistor Pack Bypass $55.00
LQ9 Coil Kit
PHR Coil Bracket Kit for GM LS2/LQ9 Coils for 2JZGTE and 1JZGTE (bracket only) $189.05
Add AC Delco D585 Coils (LQ9) $456.00
PHR Boot and Spring Kit for LQ9 Coils $60.00
PHR 170 Amp Race Alternator $314.00
PHR 240 Amp Alternator $404.00
PHR Charge Cable Kit for Alternators $108.00
Engine Dress
PHR Air Induction Plate, Polished $125.00 $99.00
PHR Billet Spark Plug Cover, No Script, Polished $221.00
PHR Billet Spark Plug Cover, Specify "Supra" Script, Polished $221.00
PHR Billet Spark Plug Cover, Specify "PHR" Script, Polished $221.00
PHR Billet Spark Plug Cover, BLACK EDITION "2JZ-GTE Turbo" $255.00
PHR Billet Spark Plug Cover, BLACK EDITION "2JZ No Shit" $255.00
PHR Billet Water Pump Pulley Cover $55.00
PHR Billet Water Pump Pulley Cover (Black) $63.00
PHR Billet Oil Cap $54.00
PHR Billet Oil Cap - BLACK EDITION $64.00
PHR Radiator Plate - Polished $68.00
PHR Radiator Plate - BLACK EDITION $68.00
PHR Billet Radiator Support Brackets $55.00
PHR Billet Radiator Support Brackets - BLACK EDITION $71.00
PHR Billet Wire Harness Hole Block Off Plate for 93-98 Supra, all SC300 $79.00
Engine Upgrades
PHR EGR Block Off Plates for Supra TT $72.00
PHR EGR Block Off Plates for Supra NA $72.00
PHR Solid Engine Mount Set, 93-95 Style $159.00
PHR Solid Engine Mount Set, 97-98 Style and SC300 $159.00
PHR Billet Tensioner Bracket $148.00
PHR Modified Oil Pump $248.00
PHR Vacuum Distribution Plenum $47.00
PHR Oil Filter Union $44.00
PHR Billet Cam Sensor Delete for 2JZ-GTE $94.05
PHR Modified 2jz Timing Belt Drive Gear $118.00
PHR Oil Filter Relocation Kit (for use without stock oil cooler) - Red/Blue Hose Ends, Stainess Line $259.00
PHR Oil Filter Relocation Kit (for use without stock oil cooler) - Black Hose Ends, Stainess Line $259.00
PHR Oil Filter Relocation Kit (for use without stock oil cooler) - Black Hose Ends, BLack Line $259.00
PHR Oil Filter Relocation Kit (for use without stock oil cooler) - Nickel Hose Ends, Stainess Line $259.00
PHR Oil Filter Relocation Kit (for use with stock oil cooler) - Red/Blue Hose Ends, Stainess Line $259.00
PHR Oil Filter Relocation Kit (for use with stock oil cooler) - Black Hose Ends, Stainess Line $259.00
PHR Oil Filter Relocation Kit (for use with stock oil cooler) - Black Hose Ends, BLack Line $259.00
PHR Oil Filter Relocation Kit (for use with stock oil cooler) - Nickel Hose Ends, Stainess Line $259.00
PHR 3 Piece Billet Aluminum Pulley Set for 2jzgte (includes Alternator, P.S. Pump, and Water Pump) $132.00
PHR 3 Piece BLACK EDITION Billet Aluminum Pulley Set for 2jzgte (includes Alternator, P.S. Pump, and Water Pump) $188.00
PHR 4 Piece Billet Aluminum Pulley Set w/ idler for 2jzgte (includes Alternator, P.S. Pump, Water Pump, and idler pulleys $204.00
PHR 4 Piece BLACK EDITION Billet Aluminum Pulley Set w/ idler for 2jzgte (includes Alternator, P.S. Pump, Water Pump, and idler pulleys $268.00
PHR Billet Aluminum Idler Pulley for 2jz $87.00
PHR BLACK EDITION Billet Aluminum Idler Pulley for 2jz $119.00
PHR Billet Aluminum Power Steering Pulley $71.00
PHR BLACK EDITION Billet Aluminum Power Steering Pulley $103.00
PHR Billet Aluminum Water Pump Pulley $55.00
PHR BLACK EDITION Billet Aluminum Water Pump Pulley $87.00
PHR Billet Aluminum Alternator Pulley $39.00
PHR BLACK EDITION Billet Aluminum Alternator Pulley $63.00
PHR Gen 2 Breather Kit for Supra, Red & Blue Fittings, Stainless Line, Left Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Black Fittings, Stainless Line, Left Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Nickel Fittings, Stainless Line, Left Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Black fittings, Black Line, Left Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Red & Blue Fittings, Stainless Line, Right Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Black Fittings, Stainless Line, Right Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Nickel Fittings, Stainless Line, Right Hand Drive $527.00
PHR Gen 2 Breather Kit for Supra, Black fittings, Black Line, Right Hand Drive $527.00
PHR Throttle Cable for Supra/SC300 for Hypertune intake manifold, Left Hand Drive $116.10
PHR Throttle Cable for Supra/SC300 for factory intake manifold, Left Hand Drive $102.60
PHR Throttle Cable for Supra/SC300 for Virtual Works intake manifold, Left Hand Drive $116.10
PHR Throttle Cable for Supra/SC300 for Greddy intake manifold, Left Hand Drive $116.10
PHR Throttle Cable for Supra/SC300 for factory non-turbo intake manifold, Left Hand Drive $102.60
PHR Throttle Cable for Supra/SC300 for Hypertune intake manifold, Right Hand Drive $138.60
PHR Throttle Cable for Supra/SC300 for factory intake manifold, Right Hand Drive $125.10
PHR Throttle Cable for Supra/SC300 for Virtual Works intake manifold, Right Hand Drive $138.60
PHR Throttle Cable for Supra/SC300 for Greddy intake manifold, Right Hand Drive $138.60
PHR 40 Row Oil Cooler Kit for 1993-98 Supra (Specify Color) $764.00
PHR 40 Row Oil Cooler Kit w/ Power Steering Cooler for Supra (rubber line on power steering)(Specify Color) $854.00
PHR 40 Row Oil Cooler Kit w/ Power Steering Cooler and Braided Stainless Powersteering Hose for Supra (Specify Color) $944.00
PHR Billet Valve Covers for 2JZ $1,075.00
PHR Billet Breather Manifolds for PHR Billet Valve Covers (each piece) $54.00
PHR Billet Adjustable Locking Cam Gear for 2JZ/1JZ Engines - Machined Finish (each) $130.00
PHR Billet Adjustable Locking Cam Gear for 2JZ/1JZ Engines - Black Edition (each) $148.50
PHR Billet Adjustable Locking Cam Gear for 2JZ/1JZ Engines - Polished Finish (each) $159.00
PHR Adjustemt Lock Kit for PHR Billet Cam Gears $36.00
PHR Ford IAC Adapter Kit for 2JZ-GTE $151.20
PHR Ford IAC Adapter Kit for 1JZ-GTE $151.20
PHR Cam and Crank Hall Effect Sensor Kit for 2jz and 1jz $279.00
Power Steering
PHR Billet Power Steering Resevoir Tank, fits all known intake manifolds except for Greddy or Greddy Replica $225.00
PHR Billet 10AN Power Steering Pump Suction Port Fitting $39.00
PHR Economy Power Steering Resevoir Kit - Red/Blue Hose Ends, Stainless Line $242.00
PHR Economy Power Steering Resevoir Kit - Black Hose Ends, Stainless Line $242.00
PHR Economy Power Steering Resevoir Kit - Nickel Hose Ends, Stainless Line $242.00
PHR Economy Power Steering Resevoir Kit - Black Hose Ends, Black Line $242.00
PHR Deluxe Power Steering Resevoir Kit - Red/Blue Hose Ends, Stainless Line $349.00
PHR Deluxe Power Steering Resevoir Kit - Black Hose Ends, Stainless Line $349.00
PHR Deluxe Power Steering Resevoir Kit - Nickel Hose Ends, Stainless Line $349.00
PHR Deluxe Power Steering Resevoir Kit - Black Hose Ends, Black Line $349.00
PHR Deluxe Power Steering Resevoir Kit - Expert Series $445.00
Continued on next post
Discussion Starter #2 (Edited)
PHR High Pressure Power Steering Line - Stainless Line $96.00
PHR High Pressure Power Steering Line - Stainless Line, Black Cover $96.00
PHR High Pressure Power Steering Line for Right Hand Drive - Stainless Line $116.00
PHR High Pressure Power Steering Line for Right Hand Drive - Stainless Line, Black Cover $116.00
PHR Solid Steering Rack Bushing Kit for Toyota Supra $129.00
PHR Power Steering Cooler Delete (works only with PHR power steering tanks) $109.00
Dry Sump
PHR Billet Dry Sump System for 2JZ-GTE or 2JZ-GE (Base kit includes the following: Proprietary Dailey Engineering Billet T6 6061 Oil Pan (standard depth), Dailey Engineering 5 stage pump with rear drive, HTD Taper grip pump pulley, Belt, Drive Set for use on the ATI Damper, HTD Crank Pulley, Oil Filter Block-Off w/ Union adapter, Installation hardware kit) $4,113.50
PHR Billet Dry Sump System for 2JZ-GTE or 2JZ-GE (Base kit includes the following: Proprietary Dailey Engineering Billet T6 6061 Oil Pan (standard depth), Dailey Engineering 5 stage pump w/ Air-Oil Separator, HTD Taper grip pump pulley, Belt, Drive Set for use on the ATI Damper, HTD Crank Pulley, Oil Filter Block-Off w/ Union adapter, Installation hardware kit) $4,455.50
PHR Billet Dry Sump System (DRAG RACE) for 2JZ-GTE or 2JZ-GE (Base kit includes the following: Proprietary Dailey Engineering Billet T6 6061 Oil Pan (standard depth), Dailey Engineering 7 stage pump with rear drive, HTD Taper grip pump pulley, Belt, Drive Set for use on the ATI Damper, HTD Crank Pulley, Oil Filter Block-Off w/ Union adapter, Installation hardware kit, two additional vacuum scavenge lines) Rear Drive Optional $4,840.25
PHR Billet Dry Sump System (AC Package) for 2JZ-GTE or 2JZ-GE (Base kit includes the following: Proprietary Dailey Engineering Billet T6 6061 Oil Pan, Dailey Engineering 5 stage pump, HTD Taper grip pump pulley, Belts, Belt Tensioner, Drive Set for use on the ATI Damper, HTD Crank Pulley, Oil Filter Block-Off w/ Union adapter, Installation hardware kit) $5,272.50
FUEL PARTS AND COMPONENTS
Fuel Components
PHR Fuel Pulsation Bypass (Specify Color) $81.00
PHR Fuel Pulsation Bypass with Gauge Adapter $99.00
PHR Fuel Pressure Regulator Bracket, Stock Intake Manifold Mount $99.00
PHR Fuel Pressure Regulator Bracket, Fire Wall Mount (will only work with aftermarket intake manifolds like Hypertune, Virtual Works etc.) $52.00
PHR Under-Car Fuel Line Hanger for 93-98 Toyota Supra - 6AN X 6AN X 6AN (EACH, requires 5 for full kit on Supra) $36.00
PHR Under-Car Fuel Line Hanger for 93-98 Toyota Supra - 8AN X 8AN X 6AN (EACH, requires 5 for full kit on Supra) $36.00
PHR Under-Car Fuel Line Hanger for 93-98 Toyota Supra - 10AN X 6AN (EACH, requires 5 for full kit on Supra) $36.00
PHR Under-Car Fuel Line Hanger for 93-98 Toyota Supra - 12AN X 6AN X 6AN (EACH, requires 5 for full kit on Supra) $36.00
Fuel Rail Kits
PHR -8AN High Flow Fuel Rail Kit (Polished, Specify Fitting Color) $239.00
PHR -8AN High Flow Fuel Rail Kit (Annodized Black, E85 Compatible) $239.00
PHR -8AN High Flow Fuel Rail Kit for 2jzge non turbo engine (early manifold) (Polished, Specify Fitting Color) $239.00
PHR -8AN High Flow Fuel Rail Kit for 2jzge non turbo engine (early manifold)(Anodized Black, E85 Compatible) $239.00
Fuel Pump Hangers and Brackets
PHR Triple Walbro 400 (485) Fuel Pump Hanger (Will aslo hold 255lph pumps) $476.00
PHR Dual Bosch Fuel Pump Hanger $476.00
PHR Bosch 044 Sock Filter $52.00
PHR 2JZ Mechanical Fuel Pump Bracket $645.00
PHR 2JZ VVTi Mechanical Fuel Pump Bracket $645.00
PHR Billet Fuel Pickup with Weldon 100 Micron Fuel Filter and Bracket for Priming Pump (Specify outlet size, 12AN or 10AN) $602.00
Fuel Systems See Website
Intakes
PHR 4" Intake Kit for Single Turbo (Specify Coupler Color) $116.00
PHR 5" Intake Kit for Single Turbo (Specify coupler color) $180.00
PHR 6" Intake Kit for Single Turbo (Specify Coupler Color) $220.00
Intercooler Kits and Components
PHR 2.5" Drop Down Pipe Kit for Greddy 3Row $159.00
PHR 2.5" Drop Down Pipe Kit for Straight Intercooler and HKS Type S $159.00
PHR 2.5" Drop Down Pipe Kit for HKS Type R $159.00
PHR Silicone Hose Kit for Greddy 3 Row (Black) $108.00
PHR Silicone Hose Kit for Greddy 3 Row (Blue) $108.00
PHR Silicone Hose Kit for Greddy 3 Row (Red) $108.00
PHR 3.0" Drop Down Intercooler Pipe for S23/S45 Turbo Kits (Specify Intercooler and Turbo Used) $264.05
PHR 4.0" Cold Side Intercooler Pipe (For PHR 5 Row Intercooler with Hypertune Intake Manifold/Throttle Body) $380.00
Exhausts, Downpipes & Mufflers
PHR 3.0" Stainless Mandrel Bent Downpipe and Midpipe with Vband Clamps *UnCoated* $675.00
PHR 4.0" Stainless Mandrel Bent Downpipe and Midpipe with Vband Clamps *UnCoated* $845.00
Street Torque Downpipe Uncoated $297.00
Single Turbo Components
PHR Cooling Hose Kit for HKS T51 (18x1.5) $116.00
PHR Cooling Hose Kit for Garrett GT series turbo $116.00
PHR T4 Turbo Blanket - Silver $72.00
PHR T4 Turbo Blanket - Black $72.00
PHR Titanium RACE Turbo Blanket for T3/T4 $119.00
PHR Turbo Oil Drain Kit - Red & Blue $116.00
PHR Turbo Oil Drain Kit - Nickel $116.00
PHR Turbo Oil Drain Kit - Black - Braided Stainless Hose $116.00
PHR Turbo Oil Drain Kit - Black - Black Nylon/Stainless Hose $116.00
PHR Turbo Oil Feed Kit for 2jzgte $72.00
PHR Turbo Oil Feed Kit for 2jzgte - Black $84.00
PHR Turbo Oil Feed Kit for 2jzge NA-T $79.00
PHR Turbo Oil Feed Kit for 2jzge NA-T - Black $87.20
PHR T4 Oil Drain Flange $25.00 20.00
PHR Stainless Wastegate Lines (Banjo Style) $100.00
PHR Stainless Wastegate Lines (NPT Style) $100.00
PHR Drain Flange To Oil Pan on 2jzgte $16.00
PHR Stainless Boost Control Line Kit for S45/S23 Turbo Kits (includes boost solenoid, boost solenoid bracket, all stainless lines and fittings for setting up boost control on S45 and S23 Turbo Kits) $250.00
PHR Boost Solenoid Bracket (Mounts MAC, AEM, WHP to Supra strut tower) 33.00
Turbo Manifolds
PHR Street Torque Manifold (Ported Wastegate Housing, Not Coated) $280.00
Single Turbo Systems See Website
Transmission, Clutch and Driveline Upgrades
PHR 3.5" One Piece Driveshaft for Supra 6spd $828.00
PHR 3.5" One Piece Driveshaft for Supra Auto $828.00
PHR 3.5" Driveshaft for Powerglide/TH350/TH400 for Supra TT $765.00
PHR Stainless Clutch Line $76.00
PHR Stainless Clutch Line - Black Coated $80.00
PHR Complete Stainless Clutch Line $144.00
PHR Billet Differential Cover for 6 Speed $639.20
PHR Reinforcement Bars for Billet Differential Cover $320.00
PHR Front Differential Mount Kit for Supra (Ear Mounts) $159.20
PHR Weld In Differential Mounts, Rear for Supra $60.00
PHR Billet Rear Differential Bushings for 93-98 Supra - Press-In $159.00
PHR Solid Rear Subframe Mount Pair for 1993-98 Supra (Front of rear subframe, includes both sides, bushing and washer) $212.00
PHR Solid Billet Rear Subframe Mounts (Rear subframe, rear mounts) WITH bosses for sway bar $275.00
PHR Shifter Bushing Kit $67.00
PHR 1350 Ujoint Flange to Factory Toyota TT Differential Billet Adapter $130.00
PHR 40 Row Transmission Cooler Kit, Stock Auto Transmission $550.00
PHR 40 Row Transmission Cooler Kit, TH400 Transmission $550.00
PHR 40 Row Transmission Cooler Kit, Powerglide Transmission $550.00
PHR Peal-Away Shim for Supra TT 6spd Rear End Side Carriers (Per shim) $63.00
Suspension
PHR Adjustable Rear Control Arms $899.00
PHR Arced Track Bars $245.00
Wheels and Accessories
PHR Hubcentric 1/2" Spacer for Weld Racing RTS Wheels on Supra (each) $52.00
PHR Hubcentric Alignment Ring for Weld RTS Wheels on Supra (each) Front $39.00
PHR Hubcentric Alignment Ring for Weld RTS Wheels on Supra (each) Rear $39.00
PHR Center Cap for Hubcentric Ring or Spacer for Weld RTS Wheels on Supra (each) $43.00
PHR Center Cap for Hubcentric Ring or Spacer for Weld RTS Wheels on Supra (each) BLACK $55.00
PHR Center Cap for Hubcentric Ring or Spacer for Weld RTS Wheels on Supra (each) POLISHED $69.00
PHR Billet Aluminum Mag Style Lugnut M12x1.5 (each) $12.00
PHR Billet Aluminum Mag Style Lugnut M14x1.5 (each) $12.00
Interior & Safety
PHR Billet Shift Knob for Automatics $180.00
Fabrication Parts
PHR IACV Valve Bung for 2JZGTE $40.00
PHR Oxygen Sensor Bung and Plug (Stainless Bung, Zinc Plated Plug) $24.00
PHR Stainless O2 Sensor Bung for For Factory Toyota 02 sensor $32.00
Stainless Flange for JDM Stock Twin Turbos $28.00
PHR Aluminum Compressor Outlet Flange Assembly for GT42 Turbo - Includes Clamp, flange and o-ring $71.00
PHR Aluminum Outlet Flange for GT42 Compressor Cover (includes o-ring, no clamp) $52.00
PHR Stainless Turbine Inlet Flange for Precision Vband (T3) Turbine Housing $33.60
PHR Header Flange for 2JZGTE Stainless Steel $144.00
PHR T4 Open Flange in Mild Steel $28.00
PHR T4 Divided Flange in Mild Steel $28.00
PHR T4 Open Flange in Stainless Steel $48.00
PHR T4 Divided Flange in Stainless Steel$48.00
Tools
PHR Rear Differential Bushing Removal/Installation Tool $85.00
Ordered an oil pump and drain flange from you guys this morning!
Are your oil pumps put together with vaseline or assembly lube? If not, how do you recommend priming them?
Placed an order yesterday morning with Sam Pumphrey and already have the stuff on hand. Way to go!
[email protected] Attempted to do the live chat feature today when the Green Light was lit and the "We´re online! Chat with us now!" Waited about 40 minutes and nobody ever answered me. Customer Service rating was reflected based on this inconvenience. I am looking to upgrade my cooling system and my upper water neck. I already have a C&R racing radiator with a -16 aluminum fitting. Would it be possible to have the PHR Billet Race Waterneck with a -16 fitting made? I also don't want to do any type of modification to the upper timing belt cover. The threaded temp sensor holes I don't need either. I will make my own. Is this possible and how much would the price be since this one with the -20 AN fitting costs $239.20 Black Friday Sale price? Also I am wanting to purchase the lower water neck for the 2JZGTE -20 AN for the Black Friday Sale price of $84. Now that I will have to wait for an answer, can I get the deal on the lower waterneck and the upper waterneck if you could make it to my specifics on Friday Dec 2nd 2016 for the Cyber Monday Sale Week?
Discussion Starter #13
Sorry about the livechat. Nobody has been online today. Not sure y it's showing green. This shouldn't be a problem at all, but the 16 will need to be welded. The sensor holes can just have plugs installed if you aren't going to use them. Pm me industry I'll give you some more details tomorrow.
I blame the Midwest Sect.
My shipment showed up this morning! Thanks again guys! This is like the 5th shipment from you guys, lol.
This is ridiculous, their chat is never on, they don't reply to emails , order tracking on their site does not work, 22 days without communication
I will have to put through a charge back on my credit card Monday if you guys don not reply
1 - 20 of 27 Posts
