Hi,
I have the PHR street kit in my car. I hit full boost around 3800 rpm.
www.sidwin.com/supra/dyno.jpg is where u can see it. The setup comes with a cast steel manifold. I also have some pics at
www.sidwin.com/supra/single too.
My car has the following mods that made the 570 rwhp STD run:
TRD Twin Disk with Lighten Flywheel ( Peter Blach)
Greddy FMIC 3 row (Thanks Mr. Billcollector Wong)
Greddy Type R bov (Thanks Mr. Billcollector Wong)
Greddy Boost, egt, fuel pressure 60 mm gauges (Thanks Gary Huang)
Greddy Power Extreme Exhaust
BCC from DirectedEngineering.com (Dimitri)
3 inch KN Intake ( Jarrett )
PHR Street Single Turbo ( Jarrett )
PHR Fuel Bypass ( Jarrett )
PHR Radiator Hardpipe ( Jarrett )
PHR FMIC plate (Dusty)
PHR High flow pump running 12v ( Jarrett )
EGR block off plate (Rich Baratta and Mohammed Alheriaz)
HKS AFR ( Jarrett )
HKS EZ ( Jarrett )
Added afterwards
Wideband o2 gauge (Rich Baratta, Dimitri and DIY)
HKS VPC (Oolan)
please note that this was done on RACE GAS, 27 psi, NO VPC. Please note that the dyno numbers are STD and I don't know what the SAE ones are. If you have any questions please feel free to email me
[email protected] or jarrett
[email protected] or dusty.
This car has been a joint venture with MVP and PHR. I prototyped the kit for them. Jarrett worked out many problems that we had. 2 months later i have the car back and their are a couple of minor things to work on. My car needed the VPC. Rerouting the bov back through the intake didn't help me much. The HKS AFR didn't solve it completely either eventhough HKS stated that the EIDS system would correct the problem
. I originally had an APEX AVC-R and APEX AFC. My car stalled horribly but the VPC fixed it like black magic
I also had to get the PHR high flow pump because my car was running god awfully lean. Also please note that to obtain the level of RWHP the stock fuel system had to be modified. Fuel Dampener bypass is a must and I would recommend everyone to upgrade your pump with either dual stock, walbros, bosch or PHR pumps. Please don't try to skip key points. I am also getting my injectors balanced and blue printed. I run fuel injector cleaner through my car atleast twice a year. I also got the Fuel Pressure gauge to make sure I don't mistake my car feeling faster from because the car is running to lean. I would also recommend an aftermarket Fuel Pressure Regulator. in the days to come, several people will be having stock fuel rails capable of placing an aftermarket FPR on them (
www.directedengineering.com). I keep my boost on the street to 12 psi. Please don't go out and get this kit and try to run 27 psi on stock fuel system when you haven't taken the proper safety measure. I wouldn't want anyone to go burn a motor just because my car dyno at a certain power. Toyota engineers designed this car with lots of safety margin. We push that margin to the extreme because we want to pinch and save. Then we wonder why the car doesn't perform.
I spool pretty quick. Full boost at 3800 rpm. The racegate is vented to atmosphere which makes it a tad bit loud. A part of the support bracket had to be removed to allow the racegate to vent to atmosphere. I am in the process of getting a heat shield fabricated or maybe ceramic coated from Jet-hot 2000. Please remember like any other project the entire cost will be more than you think it is going to be. $3800 is to start with for just the kit, then you have to add on other cost like, fuel pump, vpc, etc. For example, my car needed the VPC and pump. I could have lived with the car stalling 10% of the time, but that would have annoyed me and taken the pleasure out of driving. So please budget properly.
Thanks,
Sid
www.sidwin.com
