1 - 13 of 13 Posts
67mm of pleasure
Does anyone have pics of their 1jz using some sort of oil filter relocation kit? I looked on here but didn't find any...maybe didnt look hard enough or was just too tired after I got off work. Thanx everybody.
ma70-7m=1JZ
I have one on my car. Its not totally hooked up yet. I just have the filter adapter screwed on right now. I got the Trans Dapt kit. It was like $50. I will post pics when I am done.
Republican
Yea I have considered it... I just havent bought the adaptor yet...
i dont see much point in relocating the filter just to move it, the stock location is really accessable. If you want to run a external cooler as well, then just use a sandwich adaptor and remove the stock water/oil cooler.
most sandwich adaptors come with an assortment or bolts, at elast the one i bought did. Get the universal one. I used a Derale universal oil cooler kit. The sandwich adaptor is the same.
going broke fast
i think the fram block addaptor is a hpk5 IIRC.i used a relocator on my firebird and had my engine temp. run 5 deg. cooler consistantly.i never had an aftermarket temp gauge on the supra to see if it would yeld the same results
keith
1 - 13 of 13 Posts
