Finally!! A fan kit worthy of the Supra!! Thanks to AAP Motorsports for making it, I've been wanting something like this for years.
I had to share some pics of this kit because I'm personally excited about it. Thanks to Steve K. for the pics, this shows the kit installed on his car.
This kit is a bolt-on to every radiator: OEM, Fluidyne, Griffin, PWR, Koyo. Note on the Fluidyne only it requires one bracket to be bent 180-degrees around which is rather simple to do (pliers).
This kit includes 2 of the highest flowing Zirgo fans available. The stock clutch fan produces 3,300 CFM of air. The dual Flex-A-Lite fans produce a low 1,200 CFM. This dual fan kit produces 3,350 to 3,400 CFM! No more worries of overheating by installing an aftermarket kit!
The price includes the custom shroud and both fans, fully assembled and ready to install! All you do is wire it up to anything that gets power power when you start your Supra (alternator for example). No thermostat necessary!
Look how awesome it looks installed on a Supra!!
It is available in polished for $399 and unpolished (standard aluminum look) for $349 if you don't like the bling factor. In stock at MVP, on our website in the Cooling Components section of the MKIV Supra section. Fits NA and TT, all years.
Thanks,
Dusty
Thanks,
Dusty
