Typical for a BPU Supra, my clutch is starting to go. I don't race the car or give it much abuse, but no one drives a Supra slowly. I need recommendations from the experts.
I was leaning toward a RPS stage 2 clutch or an ACT street clutch. However, since I will also need to replace my flywheel, should I consider a different clutch with a lightened flywheel? For example, if I went with the Mueller lightened flywheel, would I need a different clutch (like the RPS stage 3)? Is the clatter from a lightened flywheel and issue?
In summary . . .
Is there much benefit from a lightened flywheel at BPU or BPU+s?
Is clatter from the flywheel too much to stomach?
Finally, what would you do if you were in my shoes?
Thanks in advance for all your feelback,
Chris
Irving, TX
In summary . . .
Chris
Irving, TX
