1 - 4 of 4 Posts
i made a post awhile back ago about after installing my walbro i noticed problems with revving when warm. last night i took out the tank again and checked everything and even made new wires. put it back...drove around same problem. when revving it up after a 20min drive it would bog at times. like studder then it will go away if i rev it a couple times. but all the time when i hold idle at about 2500 rpm or less the car has a slight miss. so i redid my cps wires again with better crimps same thing...any ideas? thank you
You're probably just running pig rich. Do you have a wideband or a tuning device? You really need both with your setup, not to mention an adjustable AFPR would no doubt help.
yea i got a afpr set at like 32psi though...pig rich would cause a little miss? wideband is going in soon
wats everyone elses fp?
1 - 4 of 4 Posts
