Alpha for president
Ok.... i've searched and searched for maybe 2 hours. I have a basic race head from virtual works +1 valves etc... and HKS 280's. i've been reading that these cams make the motor interference and that they do not. Whats the deal?. Lets just say the block was resurfaced with very minimal materal removed along with head say a couple thou.
So if the motor is now interference, ok...i'll be fine unless the timing belt breaks??
so my other question is with the minimal materal removed, am i going to have to worry about the piston to valve clearance with stock headgasket???
Yep...
They make the motor an interference motor.
Lets just say the block was resurfaced with very minimal materal removed along with head say a couple thou. So if the motor is now interference, ok...i'll be fine unless the timing belt breaks??
IF you're statement on material removal is correct, you have no problems. If you break the timing belt, you are going to hurt something.
Nope.
Alpha for president
haha...short and sweet...thanks... i know i should have done some more research before buying everything....but i didn't so...
Alpha for president
they are already in...thanks anyways
