I just installed my 61 kit and will be running off of the stock maf. How do you run a hose from the iac to the intake; more specifically how do you plumb it into the intake. Thanks- and a pic would be great if anyone has some.
Boost Junkie
I am running a 67 with the MAF. See pic here:
is that just a drilled fitting?
(thanks for the pic btw)
When cars say, "NO MORE!"
i have the sound performance pipe when i had the sp budget kit and was still on maf...its a hard pipe that is coated and runs to almost the back of the valve cover...then the factory hose takes over so you dont have to run a rubber hose that distance...let me know if you want it
what happens if you let the IAC valve breathe to the atmosphere
what happens it you dont route it behind the MAF meter and just let it breathe into the atmoshpere or put a filter on it??????
