1 - 4 of 4 Posts
· 1jz killer
today when i was removing my IC pipes, they are metal custom pipes, i found some oil in there, it is a brownish color like if it was a BHG victim, but i check my oil everymorning, and i see the color of the oil is fine, coolant is also fine, red and stuff as usual, radiator is full, oh yea and i have a spearco IC with 60 trim. also when my friend checked out my timing it moved from 12 to 15, does anyone know why it does that?
· Premium Member
the oil is from the PCV system man, if you get a catch can or run it to atomosphere it should fix that problem, and did you check the timing wit diagnostic mode shorted out? aight peace :wtf:
1 - 4 of 4 Posts
