1 - 10 of 10 Posts
SF Zombie hunter
I know they came with ceramic turbines which cant be boost over 15psi for extended amount of time. I was wondering if is possible to upgrade the turbine to steel ones and u can venture over 15bar without worryin blowing the turbo up.
Yes its possible, but no maker in the states has done it yet. In australia and in england there are shops that have done it. I currently have a set on low priority at a rebuilder, not so concerned now as i have purchased the turbo kit i wanted fromd ay 1, but i started it and i will finish it because someone has spoken up and wants them when done. Do a search, this is a fairly common subject.
ma70-7m=1JZ
2damax- What are you talking about, you dont even have a 1JZ???, you were talking about parting out your Supra because it had a BHG :dunno: A bhg is a weekend fix job!!
1JZ BLING!
I don't understand..
Your power goals aren't high, but you want to upgrade the twins?
Upgrading the twins and getting a Y pipe, and the fuel you need to boost over 15, will total probably cost more then your Supra.
I've got upgraded twins.. enlarged steels, bearings, wastegates etc... good for 2bar but they cost a lot. In retrospect i should have gone single.
PS anyone thinking of using larger twins to keep the lag down.. dont. Lag is huge on my twins... 4000rpm before full boost. They dont spool at all below about 2800.
1JZ BLING!
That is the problem with twin upgrades. Expensive and you are still stuck using the Y pipe or pay tons for an aftermarket one.
It would be much cheaper to build a couple of twins on the stock manifolds both pointing forward.
1 - 10 of 10 Posts
